Technical => Engine and Transmission => Topic started by: steveo3002 on April 20, 2015, 12:20:58 PM
Title: oil pump chain tension
Post by: steveo3002 on April 20, 2015, 12:20:58 PM
does anyone have much experiance with the polo oil pump chain and its tension
from what i can find the tension should be about 3mm , mine is much slacker and a new one on max tension is a smidge tighter like you would expect from a fresh chain
is 3mm right ?  should i be able to get it that tight?
pulleys look fine for wear
