Technical => Engine and Transmission => Topic started by: Dead_dub on March 08, 2015, 03:37:38 PM
Title: Funky noise gearbox???
Post by: Dead_dub on March 08, 2015, 03:37:38 PM
Hi all I'm lovin my G at the mo but I got some funky noise
Ok so if I'm sitting with the engine running I can hear a high scrapping
Noise maybe like metal on metal something it should be making anyways
But it go's away when I push the clutch in. And comes back when I let the clutch
Out agin.
Also I can hear a bit of a whiny if I decelerate in 1st.
A bit like the sound you get when you revers.
Has anyone had this before. I'm guessing it's a lay shaft
And getting the gearbox rebuilt would sort it.
If so anyone know when to go and how much.
Is it time to up rate it?
Could I just change the oil and get by for a bit
Till I got the grand to quaff it.
Thanks all Glyn
Title: Re: Funky noise gearbox???
Post by: AdzCM on March 08, 2015, 05:28:37 PM
New release bearing? How is your clutch cable adjusted? Have you allowed a little bit of slack in the fork?
Can't say much about the whine in first gear other than, why are you decelerating in first gear? First gear is just to get the car moving so you can use 2nd as soon as possible. Wouldn't decelerate in first ever really.
I'd look to see your clutch cable adjustment incase the release bearing is up against the clutch plate constantly. Then remove the box and see if you need a new release bearing before rebuilding the gearbox?
Would help if you had a video of the noise?
Oil definitely in the gearbox?
Adrian
Post by: Dead_dub on March 08, 2015, 07:10:19 PM
Hi thanks for the reply
Yer it was me just trying to fine out what it
Was the staying in 1st. Not something I usealy do lol
I haven't had the g long so will have a look
At the cable tomoz.
I did think the bearing but it's like the revers
Of when one go's.
If you have a email I will mail you a Video
Thanks glyn.
Post by: vwmk3jon on March 11, 2015, 08:37:54 PM
mines noisy too... gearbox is fubared tho!
Post by: hayesey on March 12, 2015, 09:17:33 AM
assuming the gearbox still changes gears normally then my money is on it being the release bearing
