Technical => Engine and Transmission => Topic started by: ian on February 11, 2015, 05:03:19 PM
Title: 4 branch manifold
Post by: ian on February 11, 2015, 05:03:19 PM
I'm just fitting a stainless 4 branch manifold I bought off another member, I'm fitting it onto my 91 GT. When I fasten it to the block the exhaust only clears the bottom of the engine by a few mm's. Is that normal?
Ian
Title: Re: 4 branch manifold
Post by: randombadger69 on February 20, 2015, 04:48:46 PM
I've had the same, but it touched the block. It was on the car for some time until I noticed when removing the engine.
Could always knock the corner of the block off with a 36 grit sanding disc. Assuming it's on the bit I think it fouls; I can't see it causing a problem to put a chamfer on it. Entirely your discretion. That or tweak the pipe or use an additional exhaust gasket.
Post by: hayesey on February 21, 2015, 04:30:10 PM
should be ok as long as it's not actually touching.  It shouldn't be able to move once tightened up, best to have a flexi piece in your exhaust though.
