Technical => Engine and Transmission => Topic started by: physicsfool on January 05, 2015, 03:47:38 PM
Title: Running hot
Post by: physicsfool on January 05, 2015, 03:47:38 PM
Hi,
Coming to the end of my 1341 rebuild and conversion into a mk2, now i have had to swap to a smaller rad (to accommodate the g lader) and pop a low temp thermostat in, but with the IC partially obstructing the rad i am worried it will run too hot?
Is a oil cooler recommended and if so 10 or 13 row?
Martin
Title: Re: Running hot
Post by: hayesey on January 05, 2015, 03:51:32 PM
oil cooler is a good idea in any case.  The biggest you can fit I'd say, just use a thermostatic take off plate.
Post by: physicsfool on January 05, 2015, 04:05:28 PM
Cheers, I will make sure its a thermostat number then.
Any other suggestions? I haven't got a particularly heavy foot as i am too pikey to pay for fuel so it wont be getting thrashed but will be driven fairly frequently
Post by: Andy on January 05, 2015, 04:35:40 PM
Low temp thermostat will make very little difference unless it manages to flow more than a normal one once open!
Post by: physicsfool on January 05, 2015, 04:48:49 PM
Quote from: Andy on January 05, 2015, 04:35:40 PM
good to know, only difference i am aware of is its ability to open at slightly lower temps. once up to temp i will need to rely on an oil cooler and hope the rad does its job
Post by: samg40 on January 05, 2015, 08:58:04 PM
I bought one of the ally rads from eBay not long back. Made a big difference on track. Temps were very stable around 90 instead of rising to over 100 after a few laps.
Post by: physicsfool on January 06, 2015, 01:18:21 PM
I think an ally rad will be the next purchase once i have run it in and require a bit more cooling
Post by: Matty! on January 29, 2015, 07:49:52 PM
I used to suffer this issue, I got one of the ebay ally rads (actually direnza) and an Oil cooler, the car barely struck 90' afterwards instead of going up and down like a yoyo!
Did a ring trip and summer driving all fine.
I went for a APS 10 row cooler IIRC with a MOCAL thermostatic plate.
