Ok, so i think i am getting to the stage where i need a shell, countdown has begun on the house i am currently in so i have 30 days to amass my polo parts and put them into another shell.
- Needs to be solid and rolling
 - Grey, blue and black are preferential but will take anything
 - doesn't have to be a genuine G shell, and open to anything from the mk2 era
I can pick up but would prefer as close to the North east as possible
				May possibly have my grey one as a shell soonhave a look at my last post for sale ad . I will obviously remove engine and etc but brakes etc will still be there.
				comet blue mk2 polo
A Reg 1984
75k 'GF' 1272cc Engine - partially rebuilt see below
4 Speed Gearbox
Top-fill radiator - new
Aftermarket sunroof
VWII Brakes with 239mm discs
Powerflex Anti-roll bar bushes
G40 Steering Damper
G40 Steering Arms
G40 Track Control Arms
Straight through stainless steel system
Black carpet in good condition
Black headliner uncut - supplied but not fitted
GT Front seats in Grey
60mm lowered front springs and uprated shocks, new top mounts and bump stops
40mm rear lowered springs
New front/rear brake flexi hoses
Its had a respray at some point in its life, the paint is in really good condition!
The following has been replaced on the engine
Crankshaft Seal (Gearbox End) 068103171F
Crankshaft Gasket (Gearbox End) 026103181B
Crankshaft Gasket (Oil Pump End) 052115189B
Crankshaft Seal (Oil Pump End) 068103085E
Oil Pump Drain Pipe Gasket 052115257A
Water Pump Gasket 030121043B or 030121043A
Sump Gasket 032103609B
Sump Washer N0138492
Flywheel Bolts N90206103 x6
Cambelt 052109119
Oil Filter 056115561G
Ignition leads
Spark Plugs
Rebuilt Seat Ibiza Mk1 Distributer and electronic ignition conversion
NOS Alternator
Engine block has been painted blue,
Has a few shell modifications
Crossmember was previously removed for the turbo conversion, a new crossmember has been welded in
Holes made in front valance for intercooler airflow
Couple of minor alterations to front panel to allow radiator to clear turbo that was fitted
Upper bulkhead hole for Mk3 Wiring loom (ecu in rain tray to engine bay)
Battery tray, part of the inner wing and jacking point were all rotten, this has all been cut out and welded up.
Studs welded to rear chassis leg to allow mounting of Mk3 Fuel pump assembely
Mounted gauges in dash.
All rot cut out of the fuel filler area, repaired, epoxy-mastic'd, seam sealed, overpainted and undersealed.
Black Coupe S arches all round, and lower sill trims
Asking price £1,000 no mot - comes on boggo steels
With MOT £1,200
				Dub diaster's gt shell will be up for sale soon. Been stitched welded as well.
				Could buy my whole car :P comes complete with everything needed
				Quote from: Jezza-7 on October 02, 2014, 01:11:42 PM
Will keep an eye out for that
Quote from: z3i on October 02, 2014, 01:28:15 PM
It is a magnificent shell but unfortunately i don't have the extra coin needed to buy the engine as well, but my pistons turned up today so may have a rebuilt engine in a few weeks
				my shell is for sale has been stich welded and the chassis legs have been strengthend thena ll seams re sealed, in great condition can come with as much or as little you want in it to be honest! can have full interitor with reclining buckets and flat rear floor, or completley bare, can come with engine or without or just with wel.... whatever you want really get in touch and we can talk about a price if you want it and take it quick ill let it go pretty damn cheap!!
				What colour's your shell dub-disaster? I've been (casually) keeping an eye out for black mk3's for 18 months now, only seen 4-5
				Quote from: ereeiz on October 09, 2014, 01:17:20 PM
Its white
				Bump
				I've got a G40 shell I could part with, could let it go as a rolling shell but it would have a standard rear beam on it.
				I had a look at it pal, very nice! you are just too far away.
