Technical => Engine and Transmission => Topic started by: z3i on September 09, 2014, 09:46:26 AM
Title: big end cap direction?
Post by: z3i on September 09, 2014, 09:46:26 AM
Currently rebuilding a g40 engine I didn't strip, Haynes helpfully says which way round the main bearing caps go but not the big end caps, got the right order as luckily they've been stamped, but unsure of which way round
Do both the little recessed bits sit on the same side? As it looks like they did on mine as you can faintly see a witness mark
Just wanted to make sure, the flat line in the bottom is the flywheel side?
Many thanks
