Hi Guy's,
I've just mounted the G60 in the polo and with the MaxRPM conversion bracket in place it moves the oil return to far away, as this hasn't been done that much i'm finding it hard to get any info.
From what I have read extending the oil return can actually have a big impact on oil pressure (which we don't want). I should be able to find a longer pipe but wondered what peoples thoughts were?
Also if anyone has done this maybe some info on where they sourced the oil return hose from would be a time saver, i'm looking at a "G60" one which is a little longer I believe?
TIA Mark.
G60 are the same.
Do max or bartek not do one?
I have G60 one, cut on the right length and no issues so far.
Awsome cheers I thought it would be ok but thought its worth checking,
