Technical => Engine and Transmission => Topic started by: Jimmy B on May 18, 2014, 07:05:17 PM
Title: Polo G40 bottom pulley Allen bolt torque
Post by: Jimmy B on May 18, 2014, 07:05:17 PM
Does anyone know how tight these are supposed to be?
Cheers,
Jimmy
Title: Re: Polo G40 bottom pulley Allen bolt torque
Post by: randombadger69 on May 19, 2014, 01:22:31 PM
From memory I thought they were the same as a camshaft pulley. Which is 56 lb/ft from memory. I'll check later when I have the Haynes to hand.
Post by: randombadger69 on May 19, 2014, 05:05:39 PM
Sprocket bolts are 59 lb/ft.
Socket head cap screw 8x1.25mm torque setting is 42.6 Nm dry and 32.1 Nm lubed.
Couldn't find it in the haynes. That's the recommended torque setting from the spec. Sheet I use at work.
Post by: AdzCM on May 19, 2014, 06:20:06 PM
In the Haynes manual are these not listed as 'auxiliary drivebelt pulley bolts' in which case they are 20nm? Page 2A.2
That's what I tightened them too anyway.
Post by: randombadger69 on May 22, 2014, 01:18:18 PM
You are quite right. "Drive pulley bolts". Spotted it on closer inspection.
