Don't really understand this, not much came up on Google. But looking up pedal boxes on the net and alot of the ones with the design I'm looking for have a master cylinder and hydraulic accelerator? Is something like this possible? Never seen it before and can't find much info on it apart from a few kit cars
Is it a worth while mod? Is it as simple is making brackets for a slave cylinder at the throttle butterfly mechanism or is something I have missed? Apparently it makes for a very smooth throttle
				This is an oxymoron surely?
I don't know any pedal boxes which have a hydraulic accelerator... plenty have a hydraulic clutch (which I think is what you mean?)
Polo clutch can be converted to hydraulic, leave the throttle cable, and the brakes hydraulic...
I don't know f anything which runs a hydraulic throttle, cable, rod, electronic yes, hydraulic, no  ???
				Didn't realise it existed, no real need to reduce the effort levels of a cable/rod set up
				Not hydraulic clutch, I'm looking at pedal boxes as I'm going to convert to hydraulic clutch. Definitely hydraulic accelerator. Apparently it's common. Conversion on dune buggy/sand rail type things? From what I've been reading I don't really get it, it's definitely a thing lol not me being stupid
I don't understand why on the motorsport pedal boxes I'm looking at it has a mastercylinder behind the throttle pedal? Another behind brake pedal and another behind clutch?
I thought I might convert my brakes to cable yoof.. :P
Unless I'm being stupid and there's two master cylinders, one for front and one for rear? They just placed the one for rear behind the throttle?
				You've already got a cable brake...
Anyway- the pedal boxes you're looking at with 3 master cylinders will have 2 for the brake and a single for the clutch.
I've never heard of a hydraulic throttle... can't see any reason for one either.
				Quote from: Yoof on April 30, 2014, 05:47:54 PM
Apologize for my retardness :( they defo exist though! the only benefit would be it not seizing up in arctic conditions? just a guess, i know sometimes you can get water in the outer casing and then it freezes? just a guess
again sorry for this, it was confusing the hell out of me, put was just my stupidity, i read into pedal boxes and i now see the balance bar controls both master cylinders
i hear your coming this weekend? woop :D
				i never seen a hydraulic accelerator in my life. most motor sport pedal boxes have two master cylinders for the brake pedal don't they?
				Quote from: RyanC on May 01, 2014, 06:27:30 PM
Yes... Yes they do... I've always been under the impression they have one lol, now I know
Google it, definitely exists! Regarding pedal boxes depending on what master cylinder I get it should make a huge difference in pedal feel?
				U don't need a hydro throttle man, hydro clutch is a good idea and easy to do but that's all u will need, plus u would have a slave cylinder by the TB and would look messy, cable dose the job fine imo
