As in the title. These can be sourced in packs of 10. Which is not much use unless buying 20. So anyone interested? Would work out around £12 a plug.
I got mine from Gsf no problem id give them a try
Ngk equivalent are just as good and half the price
At £6 or £7 I might, but £12 each means £48 for plugs when NGK's are half that...
What youse using?
NGK BPR7 EVX?
Has been superseded with an iridium plug with a resistor? Built in.
Are the number up BPR8's suitable for a standard G?
I think yoof runs the 8's.
This might help ;)
http://www.polog40.co.uk/forum/index.php?topic=10351.0
Thought I'd found a cheap source for these. . Knew it was too good to be true.
KMS on ebay list them as W5DP0 but sent me W5DTC instead at £5 a plug. Chore.
So I'm still considering buying 20 off to get a good price.
Just need three people who want a set of 4.
I'll have a set of 4
I bought from ECP recently?
How much Tav?
I ended up buying 8 for the price of 10 off Kms. Not impressed. Next time I'll consider stocking some. For now though as there was little interest I'm out of organising a group buy.
Prob. around the £12 ea. mark I'd have thought. £48 sounds about right. The Clio takes platinum plugs too so it was an expensive month.
Save yourself some cash and use the NGK equivalent :)
