Hi all, Having a good clear out of all my spares as its looking like my e46 2.0d is going to need a weasel injection pump, so i need some cash!, as i doubt its going to be cheap..
All parts available for collection from TW2, or can post at buyers expense.
any further questions please call or text me on 07590767606 Matt.
Can send pics as required to phone.
Newman Camshaft (part number VOLP/268/413 PH1..) covered 15-20k, no marks. £100
G40 Throttle Body (unmolested, wedges still fitted) covered 60k £45
PPP Lower strut brace (goes between chassis points on bottom arms) never fitted, just offered up. (you will need longer bolts)  £40
PPP lower gear box mount (was fitted but made my exhaust knock so removed) covered 5k.. SOLD
G40 inlet manifold  (just needs a good clean out before fitting) £40
GT inlet manifold (also needs a good clean before fitting) £40
G40 driveshaft (long one for o/s) complete but outer cv boot split. £30
G40 alternator/supercharger cast iron engine mount (unmolested) (would prefer collection for this as its pretty damn heavy) £30
G40 Flywheel (unsure of mileage) looks in good condition, all clutch bolt holees/threads good) £40
Rear wiper motor assy (bench tested, operation all ok) £25
G40 "tea tray"  with solid boost pipe £25
G40 charger elbow and ribbed boost pipe  (not split, but pretty old) seal also missing from charger elbow £25
G40 idle stab Valve and pipework. £25
G40 "flying saucer" part for charcoal canister + most of the pipework. £30
3 x Heater blower motor assy's (all with no matrix and only 1 with a resistor) all turn freely. £20 each
o/s door mirror assy. average condition £20
1 x uk spec o/s rear light (smoked) (light scratches not cracked) £15
1 x EU spec o/s rear light (smoked, (reverse on o/s) also has light scratches not cracked. £20
o/s and n/s manual window regulators £15 each
N/s parcel shelf support (not broken like most of them ) Black, £10.
If any of this doesnt sell, will be going as spares when i sell my g40.
Best off contacting me via phone as i dont get a chance to get on here very often.
Matt 07590767606, if i dont answer, please give me a txt or leave me a voicemail.
				Hi,
Still selling that GT inlet?
				How much would the lower brace be including postage?
Ian
