Classifieds => Traders parts and services => Topic started by: OCDmatt on January 29, 2014, 01:47:29 PM
Title: Few new bits
Post by: OCDmatt on January 29, 2014, 01:47:29 PM
Just sorted a few new bits to the site
Main ones with interest to you guys will be the rebuild sets
Head set - http://www.onlychargeddubs.co.uk/products/cylinder-head-gasket-set-g40.html
Bottom end set - http://www.onlychargeddubs.co.uk/products/bottom-end-gasket-set-g40.html
Head bolts - http://www.onlychargeddubs.co.uk/products/cylinder-head-bolts-g60-g40.html
All from Elring so top quality, they're not commonly ordered so may take a couple of days to get in stock as my engineers had a bit of hassle getting the bottom end set.
Cheers Matt
Title: Re: Few new bits
Post by: PeteG40 on January 29, 2014, 01:59:11 PM
Cool - the bottom end ones are hard to come by.
Just for info Matt,  vw use different head bolts for g40 and g60s.  They g40s are higher tensile 12.9 - normal are 8.8 as per cl/gt ones and are 2mm longer. So I'd assume that these are the 8.8 ones. (as vw charge £7-8quid a bolt for g40 spec ones)
Post by: OCDmatt on January 29, 2014, 05:47:47 PM
Yeah, supplier said it was! We should be able to keep getting them, just making folk aware it might be a few days at least :)
Ah, ok, I know they've different part numbers but they've come boxed up for VW engines, 1.0-2.0. It doesn't say 8v or 16v but 16v are a lot longer.
They were ordered for a G40 from a G40 reg & engine code so these are G40 bolts. I'll do some checking to make sure they fit a G60 too :)
Post by: OCDmatt on January 29, 2014, 05:50:40 PM
Forgot to add we've now got Quaife G40 diffs in too :)
http://www.onlychargeddubs.co.uk/products/084-quaife-helical-lsd-differential-g40.html
Post by: OCDmatt on February 25, 2014, 08:38:50 AM
Just to add on to the gasket sets I'm know keeping bearing sets too....only thing I'm struggling on at the minute is con rod bearings but we're looking in to it.
Normally keep standard sizes but if you need oversize then just give me a shout :)
http://www.onlychargeddubs.co.uk/engine-parts/
Post by: Andy on February 25, 2014, 01:04:32 PM
Quote from: OCDmatt on January 29, 2014, 05:47:47 PM
Elring 819.817 are standard Polo ones. They don't do a proper G40 headbolt alternative that I'm aware of.
Post by: gaz g40 on February 25, 2014, 01:50:07 PM
I had to get g40 specific ones from VW as nowhere else did them
Post by: z3i on February 25, 2014, 03:33:37 PM
Same, and the price for them was insane!!
Post by: physicsfool on February 25, 2014, 04:09:24 PM
The BGA BK4398 have an extra 2mm on them not sure about the tensile strength though
£40 a pop
http://www.ebay.co.uk/itm/BOLT-KIT-CYLINDER-HEAD-VW-BK4398-BY-BGA-/400616412815?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d4699568f
Post by: OCDmatt on February 25, 2014, 04:13:35 PM
Elring seemed happy they'd do the job but I'm doing a double check on it!
Might have to see what I can do about getting them Genuine instead if they come back with something different.
Another thing to add, proper Kluber grease now available in little 15 gram pots - http://www.onlychargeddubs.co.uk/products/kluber-grease-15g.html
Post by: OCDmatt on February 25, 2014, 05:44:28 PM
Yep, they've changed their minds now. Will change the listing as they are G60 only.....
But.....I can get Polo G40 specific matched to part number so will be getting some in stock ASAP :)
Will be £15 plus the postage 8)
