Reviews => Company Reviews => Topic started by: physicsfool on November 21, 2013, 11:40:17 AM
Title: Stephen Brear Gearboxes
Post by: physicsfool on November 21, 2013, 11:40:17 AM
Based in west Leeds:
Butterbowl Works
Ring Road
Leeds
West Yorkshire
LS12 5AJ
Contact: 0113 263 2073
Came recommended by a few people, top set of blokes, gearbox was stripped and rebuilt with a few new seals and the whole box closed and sealed for £100 all in.
was ready to pick up the next day.
price and service was top notch
Title: Re: Stephen Brear Gearboxes
Post by: gaz g40 on November 21, 2013, 01:01:38 PM
Nice set of blokes arnt they! I hate it when you go to an engineering place an you get that vibe where they cant be arsed an are snotty.
Post by: Yoof on November 21, 2013, 01:49:29 PM
Could you list what seals they replaced?
Be good to know as JP at Silverstone usually charge £250 for this.
Post by: gaz g40 on November 21, 2013, 02:54:41 PM
I paid 150 for my new diff fitting. They gave the box a once over aswell. Changed a seal that was damaged getting to the diff?
Post by: physicsfool on November 22, 2013, 10:40:52 AM
He changed the unit thing with 2 springs that keeps the gearshift upright, and the selector seal, and another larger seal that i wasn't familiar with. He also threw in a spare selector seal and took a few minutes to explain how i should go about changing it when it starts leaking. If that isn't top customer service then i dont know what is.
We also chatted about oils and he suggested the cheapest 10/40 mineral oil (own brand morrybob) for these boxes, the higher viscosity helps the synchros
Post by: DKnight on December 04, 2013, 11:08:28 PM
had dealings with these guys too, flawless and consistent too. highly recommended.
Post by: ereeiz on May 01, 2017, 11:28:05 AM
I just read this, can you clarify they recommend 10/40 mineral oil, as in the same stuff you'd put in an engine? I thought the recommended grade was 80something? Did they put any friction reducer stuff in there, e.g.. activ8 or similar? I ask as I've recently started learning a bit about boxes and thought it was always a thick oil on older cars? I'm also considering sending my box somewhere for an inspection /overhaul so any recommendations welcomed!
Post by: physicsfool on May 01, 2017, 12:32:12 PM
My memory isn't what it used to be, however that's what he recommend. I ended up using the vw gearbox oil as i had already bought some.
I would need to have a read up on the breakdown of various oil types under pressure and temperature to understand his reasoning.
