Okay so about to put the water pump pipe on, is there a gasket for it? If so where do i get it from? Main dealers? Or can i just use sealant around the whole thing ? Cheers
There is a gasket but I have found that it doesn't do very much so I use gasket sealant on it instead.
Sounds good to me, i assumed the gasket sealant would do yhe trick. Cheers Robin.
did your new pump not come with one?
The new water pump? No it didnt come with a water pipe gasket, should it??
well, it's a while since I've bought one but I thought they came with a new rubber seal. Perhaps that's just from VW themselves though?
I bought a continental one the other day and it came it came with rubber seal. Didn't use sealant. after 500 miles still no leaks
The water pump itself comes with a ruber seal yes, but i was after the water pipe gasket.
ahhh, totally misread the post!
I just used blue hymolar sealant stuff. Has survived years of track days and stuff.
Haha i was hoping you two had mis read it, yeah i just lumbered it with sealant! Cheers guys :)
