Am I right in thinking a engine G40 mount will fit onto a 1.0 mk2 polo?
Change the inlet mani and fit the G40 TB, tweak the carb and we are good to go?
If I was to adjust the butterfly so it doesn't close properly is that a reliable enough way to limit the amount of boost?
I know its a bad idea and will blow up but we got a few weeks to kill till christmas ;D
how car you fit the g40 tb onto a carb??
Do you know what a carb is? ??? :P
i would have thought fuck the throtle body off and replace it with the carb because the carb will act as a throttle body eh
just a question of how to get the carb to flow into the inlet manifold
tbh waste of time
abit of a brain dead moment there.
Revised plan - bodge the G40 TB on top of the carb.
but the real question - can the butterfly be used to regulate boost?
Quote from: giorgio on December 06, 2008, 06:26:57 PM
oh my.......................
The hard park of that thing is to make the elbow of the boost return to work the the flap goes up and down.... In your case a blow off valve is going to be a more easy to make... For the carb now.... I don't think that the tiny carb that the 1.0l polo has can provide the needed fuel.. You'll need a bigger carb also...
fit a really big pully.........
