Technical => Engine and Transmission => Topic started by: z3i on July 30, 2013, 02:52:10 PM
Title: rocker and sump gasket sealing problems
Post by: z3i on July 30, 2013, 02:52:10 PM
Hi all
having a bit of trouble with my gaskets
vw and heritage say the rocker and sump gaskets are obsolete
ive tried sealing my rocker up with some liquid gasket on the rubber one but still leaks. Non genuine ones are crap
sump gasket i got a new genuine one and put a thin bead of gasket sealer round it but still leaks
anyone got any ideas? Getting to be a messy pain now
many thanks
Title: Re: rocker and sump gasket sealing problems
Post by: PeteG40 on July 30, 2013, 03:18:00 PM
used correct torque settings?
rockers you can get right ones from elring.
Post by: hayesey on July 30, 2013, 05:12:30 PM
sumps are a pain in the arse.  I usually put a decent amount of sealer between the gasket and the sump itself.  None between the gasket and the block but make sure the block face is clean enough to eat your tea off.
Post by: z3i on July 30, 2013, 05:42:11 PM
Thanks peeps
sorry i meant non genuine sump
i put sealer both side and got it pretty clean, ok i wont put it on the block side
i didnt pete, i didnt really think it would make much difference, clearly i was wrong lol
what is the torque for the rocker? And torque for the sump?
Cheers for the heads up on elring, gsf must supply elring ones?
the sump is card type, what is yours?
thanks for the help peeps :)
Post by: Jezza-7 on July 30, 2013, 05:59:51 PM
I dont use a sump gasket at all. Just sealant and works fine. Most cars these days dont use sump gaskets now.
Post by: Jezza-7 on July 30, 2013, 06:01:55 PM
Torque:
Camshaft cover screws    10nm
Sump                            20nm
Post by: z3i on July 30, 2013, 06:53:00 PM
Cheers for the jezza :) what sealant do you use for the sump? And do you use much? or a skinny bead?
did you get good results with it?
yeah i remember doing a autobox on a nissan note and nissan dont even make gaskets, just sent some sealing compound through
Post by: Jezza-7 on July 30, 2013, 07:13:56 PM
Something like this, http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_165466_langId_-1_categoryId_255217#tab1
Or find Loctite SI 5980. This is a better one to use.
http://www.ebay.co.uk/itm/Loctite-Quick-Gasket-5980-Sealant-200ml-/400500963781?pt=UK_Body_Shop_Supplies_Paint&hash=item5d3fb7b9c5
And then apply it by making like tear drops round the hole. Will try draw what it looks like.
Post by: Jezza-7 on July 30, 2013, 07:18:50 PM
Or like this
http://www.google.co.uk/imgres?q=loctite+apply+oil+sump&um=1&client=safari&rls=en&hl=en&biw=1280&bih=644&tbm=isch&tbnid=CIwRgg4DCXUfeM:&imgrefurl=http://www.uksaabs.co.uk/UKS/viewtopic.php%3Ff%3D2%26t%3D50487&docid=UqMgqRRHJp9B0M&imgurl=http://i289.photobucket.com/albums/ll239/johno101_bucket/The%252520black%252520one/DSCF3305.jpg&w=800&h=600&ei=lQL4UaKTFY3eOO-ugaAC&zoom=1&ved=1t:3588,r:9,s:0,i:107&iact=rc&page=1&tbnh=194&tbnw=251&start=0&ndsp=17&tx=98&ty=81
Post by: z3i on July 30, 2013, 08:11:28 PM
Your a diamond! Thanks fella :) will give it a whirl and let you all know :)
