anyone got the flywheel bolt torque settings to hand? tried searching around to no luck :/ cheers guys :) and ps does the clutch plate need to be torqued aswell?? if so what figures aswell? lol
got the flywheel settings i hope, 25nm?
but need the clutch plate torque settings if possible?
These are listed in the Haynes manual.
Fly bolts are angle tighten too
25nm is no where near, they are 60nm plus 90 degree. The clutch cover torque is 20nm for 5 speed, 25nm for 4 speed. Will post it up as well.
From Haynes
Torque wrench settings Nm Ibf ft
Cylinder head bolts (engine cold):
Stage1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 30
Stage2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60 44
Stage 3 (angle tighten) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . + one half-turn (180"), OR + two quarter-turns (2x90°)
Main bearing cap bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65 48
Camshaft cover screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 7
Camshaft sprocket bolt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 59
Inlet manifold nuts/bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 18
Exhaust manifold nuts/bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 18
Flywheel bolts:
Stage1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60 44
Stage 2 (angle tighten) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . + 90°
Sump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 15
Oil drain plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 22
Oil pressure switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 18
Crankshaft sprocket bolt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 59
Crankshaft oil seal housing bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 7
Auxiliary drivebelt pulley bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 15
Oil pump mounting bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 15
Oil pump cover bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 7
Oil pickup tube screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 7
Clutch Torque settings:
From Haynes
Pressure plate to flywheel bolts:
4 speed transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .25 18
5 speed transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .20 15
Jezza youre a legend! Thank youuu! :)
