Club G40 => General Chat => Topic started by: physicsfool on July 18, 2013, 10:38:56 PM
Title: Rollin road
Post by: physicsfool on July 18, 2013, 10:38:56 PM
Evening chaps,
So, kinda keen to know what my g is putting out. Anyone know a decent spot that charges a fair price. Or should I hit the local spot up?
Also will I damage my g by running a standard chip on a 65mm pulley?
Ta
Title: Re: Rollin road
Post by: Tav on July 19, 2013, 03:35:30 PM
If it's not running correct map for 65mm pulley it'll run lean (too much air not enough fuel)...what's the worse that could happen?  You'll melt the miston inside your engine and find yourself needing a new engine.
Post by: z3i on July 19, 2013, 05:23:42 PM
Unless you drive it off boost until your chip arrives?
Worst case scenario if you need the car
Post by: Alexiskayak_7 on July 19, 2013, 05:41:16 PM
Nothing is gonna happen mate. Fuel map is way to rich and ignition timing is way too retarded.
Post by: z3i on July 19, 2013, 06:53:02 PM
What makes you say that?
why would it be too rich? It wouldnt be too rich
and as for timing the g40 runs on the very limit of pinking, hence why it has a knock sensor
if you read the article on the forum at the front page it says so
so yes if you run under hard loads with a smaller pulley and no map too suit you *could* potentially melt a piston
however if you drive half throttle and under it wont be running on any boost and make no difference
Post by: Alexiskayak_7 on July 19, 2013, 09:21:38 PM
Quote from: z3i on July 19, 2013, 06:53:02 PM
I can't believe that a proper g40 with a good condition fuel system (pump, lines, injectors) could melt a piston. If i remember with stock chip at wot, afr drops at 11.2 (quite rich).
At the last month i was experimenting mapping my g40. I run 95oct fuel. I leaned at wot the afr to 11.5 and gave +5-6 degrees of timing and still nothing- no pinking.
Also, at higher loads (more than 0.7bar till 1) everything is safe
Post by: z3i on July 19, 2013, 10:00:05 PM
Ok mate, see were your coming from
but g40's arnt sound these days, they are over 20 years old all been fiddled with and high mileage
in my personal opinion i wouldnt risk it
plus there are people on here who have melted pistons running g-laders. Jezza melted his after getting his charger ported
Post by: physicsfool on July 21, 2013, 08:48:49 PM
From a search on the forum it would appear from years past that a rolling road session has been organised on here and included a few beverages.
Would there be interest to have another one this year? Sep/Oct time?
Post by: samg40 on July 22, 2013, 02:38:39 PM
As it happens it was something we were discussing the other week as to having a CG40 RR sometime in Sep/Oct. If there is enough interest we'd be happy to sort one out. Last time we tried we were struggling for numbers however.
Post by: z3i on July 22, 2013, 03:48:23 PM
Id be well up for it :) though im sure ill be dissapointed with my rr figures before a remap :(
Post by: Jester on July 22, 2013, 03:55:47 PM
I'd be up for this too, nice little get together, I'm going to get a fresh RR anyway in the near future.
Post by: vee-dub90 on July 23, 2013, 11:49:36 AM
Id be up for it, but my car wont be on the road for ages sadly
Post by: physicsfool on October 11, 2013, 11:29:50 PM
Still keen?
