Author Topic: Nology Coil  (Read 4705 times)
Offline Robga
Nology Coil
« on: September 14, 2008, 06:20:48 pm »
Hi
Has anyone on here fitted this Nology coil to their G40? http://www.nology.com/images/vwmodulekit.gif
Ive seen a G40 somewhere before using it but since fitting it myself my G40 is not starting so either the wires are different on the Polo than the Golf or the new coil is faulty.
Do i need to swap wires around as the coil and amp were ment for a Golf?
Rob
Offline polo classic
Re: Nology Coil
« Reply #1 on: September 15, 2008, 02:04:43 pm »
[quote pid=4112 author=H866MPR date=1221412848]Hi
Rob[/quote]
I have a Nology on mine. It is plug and play. Difficult to find a good place for the coil though
Offline breadman
Re: Re: Nology Coil
« Reply #2 on: September 15, 2008, 08:01:14 pm »
Sorry, I can't help you here Rob. I've not seen these before, I take it they're supposed to be a good upgrade? Was it expensive?
Cheers,
Richard.
Offline tdh-syorks
Re: Re: Re: Nology Coil
« Reply #3 on: September 16, 2008, 02:53:04 pm »
do these kits cause any problems to the car after time?? how much are they?
Offline Robga
Re: Re: Re: Re: Nology Coil
« Reply #4 on: September 16, 2008, 08:25:42 pm »
[quote pid=4121 author=polo classic date=1221483883][quote pid=4112 author=H866MPR date=1221412848]Hi
Rob[/quote]
I have a Nology on mine. It is plug and play. Difficult to find a good place for the coil though[/quote]
I recon i've got a dud! Tried it on my Golf just to be sure and still no good. :(
I mounted it no problem in the original place using 2 sections of aluminium and the amp up on the bulkhead.
Does the wiring look the same as yours? Just to be sure before i send it back!
Breadman - Well i thought it would be a good upgrade.......if it worked! :/
Just under £100 from USA instead of £169 here!
tdh-syorks - Not sure about if they cause problems to the car but its giving me problems!
Cheers mate
« Last Edit: September 16, 2008, 08:59:24 pm by H866MPR »
Offline tdh-syorks
Re: Re: Re: Re: Re: Nology Coil
« Reply #5 on: September 16, 2008, 10:12:12 pm »
Can see that mate. I just had a look on their web site for one. Might invest in one if there any good.
Offline Gary
  • just one last thing....
Re: Re: Re: Re: Re: Re: Nology Coil
« Reply #6 on: September 24, 2008, 08:50:29 am »
I've got one, never fitted it yet tho.
Im sure Dan (9OLO) has one on his car....
Offline FQ200turbo
Re: Nology Coil
« Reply #7 on: October 05, 2008, 10:59:58 pm »
the original coil have a 3 wire plug, the nology have 2 wire, what to do with the 3rd wire ?
Offline Robga
Re: Nology Coil
« Reply #8 on: October 08, 2008, 07:28:08 pm »
It comes with a ignition module.
If you want to use a MSD coil you will need one too. Wish id got a MSD now!
Rob
