Author Topic: LOST ALL BOOOOOST!!  (Read 4340 times)
Offline G40jamie
  • Loving the G40
LOST ALL BOOOOOST!!
« on: August 08, 2013, 05:01:01 pm »
I've had my forty up and running now for a few weeks, boosting fine no issues, and whether this is coincidence or not i don't know, but as soon as i fit my 65mm pulley, the boost slowly disappeared then just went, when we first fit the 65mm pulley anda boost gauge, was pushing half a bar, now nothing, what could this be? ive checked all the vacuum pipes, breathers, the belts and the pulley but i cant seem to find anything :/ what could this be??
Offline SuperMario
Re: LOST ALL BOOOOOST!!
« Reply #1 on: August 08, 2013, 08:16:02 pm »
Sounds like a boost hose coming off, when I fitted my 65mm kit the inter cooler hose was the issue! Just check all the boostclamps
Offline Jezza-7
« Reply #2 on: August 08, 2013, 08:20:28 pm »
Check the charger to intercooler pipe. Might of gone through the walls, after fitting toothies to mine the pipe blew.
« Reply #3 on: August 08, 2013, 08:47:10 pm »
belts tight enough.
checked the strainer in the intercooler?
Offline G40jamie
  • Loving the G40
« Reply #4 on: August 09, 2013, 01:44:37 pm »
id like to say i checked everything, might have to just take it apart and put it back together and see what happens
Offline G40jamie
  • Loving the G40
« Reply #5 on: August 11, 2013, 11:20:19 am »
think its the seals in the charger :(
Offline scotsjohn
« Reply #6 on: August 11, 2013, 12:23:02 pm »
What signs of that? Usually lots of oil pissing out the outlet when you disconnect it.
Offline Jimmy B
« Reply #7 on: September 12, 2013, 12:14:54 pm »
Check the auxilary air valve that runs to the bottom of the inlet manifold
