Author Topic: Does the white ptfe vacuum pipe go to the lower pipe on the servo feed?  (Read 2550 times)
Offline g40willa
Hi everyone,
sorry if this is in the wrong place, I'm looking for a picture of the routing of vacuum pipes, I've searched and got some info from other peoples threads but cannot find a definite layout. Moderators can we have a sticky vacuum pipe guide in this section please or can anyone point me in the right direction?. Apologies again if i'm barking up the wrong section of the forum....
the white pipe goes from the servo vacuum pipe to the ECU for the map sensor.
Offline g40willa
Thanks Haysey, is that the lower of the two pipes on the servo pipe?
It's in mk1 golf so I can't move the ecu because I've determined that it needs to stay below the rain tray. Can I extend the ptfe pipe or is that pre-set for a certain reading? Is there a diagram anywhere?
Offline tdh-syorks
i wouldn't see why you couldn't extend it, i don't think its a set length
it is a set length actually, so really it's supposed to stay like that.  I 've heard of people having problems with g60s if they have messed with that pipe.
Doesn't matter which of the two connectors it goes to on the servo pipe though as they are both next to each other and connect to the same thing.;
Offline tdh-syorks
Do u know the correct length hayesey? I  cut mine short last week to get etches g40 running. Cheers matey  :)
Offline g40willa
Thanks man. I only need it to be about 2 inches longer, but I think I'll have to re-think the wiring to bring the ECU closer to the bulkhead, it turned over last night. Exciting times.
I think ETKA/Vagcat shows the length
Offline youngprodigys
  • G 3URO
1/2 a meter if i remember correctly
  • G 3URO
1m is G60 for sure - the polo is shorter i think il go get it out and measure it lol
Offline Puncharado
Re: Does the white ptfe vacuum pipe go to the lower pipe on the servo feed?
« Reply #10 on: March 27, 2010, 02:16:44 pm »
Got my ECU in the house with the pipe attached - 47cm.
  • G 3URO
« Reply #11 on: March 27, 2010, 02:18:05 pm »
i was correct then! 1/2 a mtr
ETKA reads the plastic pipe as 460mm and both the cotton wrapped rubber end pipes as 40mm each. it is on illustration 16-60
« Last Edit: March 27, 2010, 02:22:26 pm by youngprodigys »
Offline g40willa
« Reply #12 on: March 29, 2010, 12:21:39 pm »
What does the exact length dictate? anyone aware?
  • G 3URO
« Reply #13 on: March 29, 2010, 12:59:57 pm »
pressure is dropped across a length, ecu will be calibrated for this drop
