This is what i got from the haynes manual:
VW Polo Nov 1990 to Aug 1994 (H to L Reg)
Models Covered
VW polo Saloon, Hatchback & Coupe models,
including G40 (supercharged) Coupe & special/limited editions;
1043 cc & 1272 cc petrol engines
12.2 Wiring Diagrams
Fuse Colour Code:
White 8 Amps
Red 16 Amps
Yellow 20 Amps
Fuses:
1 8A Number Plate Lights
2 8A Fog Lights, Rear Fog Lights
3 8A LH Side and Tail Lights, Instrument Illumination
4 8A RH Side and Tail Lights, Headlight Washer
5 8A LH Main Beam
6 8A RH Main Beam and Warning Light
7 8A LH Dipped Beamm LH Headlight Adjustment
8 8A RH Dipped Beamm RH Headlight Adjustment
9 8A Horn, Carburettor Idle Cut-Off Valve, Reversing Light
10 8A Direction Indicators, Seat Heating
11 8A Interior Light, Cigar Lighter, Radio, Diagnosis Supply
12 8A Stop Light, Clock
13 16A Engine Cooling Fan
14 16A Rear Wiper, Blower, Lighting Switch Light
15 8A Windscreen Wipers, Intermittent Wipe
16 16A Heated Rear Window
(1) 20A Electric Fuel Pump, Lambda Sensor ( in separate holder above the fuse box)
I dont think all of the fuses apply to the G40 as this is for quite a few polo's
Hope this helps
