Technical => Turbochargers => Topic started by: VW_rae on October 19, 2009, 10:43:59 pm
hi guys im in the finishing stages of the t40 and was wondering does any use a bleed valve or a boost controller??
i use a bleed valve till my forge actuator spring comes yellow iv gone for
so basically just get a actuator on it and i wont need to fiddle around with one of them???
yea get a actuator and dont buy a bleed valve! make sure your map is right for what even boost you run
Cant really beat a bleed valve for setting your car up, then when you are happy with the boost set about finding an appropriate actuator/adjusting your actuator.
