got some new brakes for my loon so these arent needed any more:
VW Type 1 brakes as fitted to all non G40 polos and used to upgrade early mk2s
done 48K ( original ones off my loon), have the carriers, good rubbers, sleeves etc £20 or £30 posted
VW Type 1 brake carriers can be used with Type II calipers when you run wheels with a non standard offset so the wheel doesnt hit your brakes £10 or £15 posted
VW Type II brakes of a G40 but can be used to upgrade all non G40 polos, good seals and all the nuts bolts to mount them etc £50 or £60posted
they are genuine VW items with the big VW stamped on the side not like the smooth sided aftermarket ones.
Mk2 golf rear calipers, can be used to to convert polos need the pistons rewond in but i dont have the wee tool, would sandblast them and put new seals in them before i used them but priced to suit £10 or £20 posted ( new ones are £65 a piece and you need an exchange item)
Rear polo backplates, good straight condition could be powdercoated or just wiped over with some WD40 to look good £15 or £20 posted.
located in glasgow but can post and paypal accepted
