Author Topic: toothed pulleys guides  (Read 2836 times)
Offline dazzle53
« on: April 02, 2010, 04:12:46 pm »
where can i get pulley guides for my toothies? they are PSD phase 2
thanks
darren
Offline scotsjohn
Re: toothed pulleys guides
« Reply #1 on: April 02, 2010, 08:52:36 pm »
Only guides on the alternator pulley; yours should have them if phase 2. There should be threaded holes for them on the pulley.
Offline dazzle53
« Reply #2 on: April 03, 2010, 08:12:18 am »
got the holes but no guides   :(
« Reply #3 on: April 05, 2010, 02:28:25 pm »
you'll probably need to google search some gear engineering shops and speak to them.
are these some of the PSD rip off ones that juan made then?
Offline youngprodigys
  • G 3URO
« Reply #4 on: April 06, 2010, 08:59:30 am »
I have authentic PSD toothies I bought direct from steve when I bought my eaton stuff and mine never had the guides either. he said he would post them out - but it never happened.
I got a local laser cutter company to just make me up some circles to keep the belt on mate.
Offline dazzle53
« Reply #5 on: April 16, 2010, 12:25:11 pm »
i didnt realise they were rip offs but they are from juan  :(
Offline scotsjohn
« Reply #6 on: April 16, 2010, 08:56:33 pm »
Also, while you're getting things sorted, check the size of the slot in the alternator pulley. PSD ones have the wrong dimension for the Woodruff Key(at least mine have). They've cut it the same size as the charger pulley when it should be smaller. If yours has this problem then get the slot in the alternator pulley re-cut, the key slot in the alternator shaft opened out, or do a bit of shimming with strips of feeler guage.
