Author Topic: Eaton charger, what pulley sizes are you using?  (Read 2689 times)
Offline Richg40
« on: June 29, 2011, 01:57:17 pm »
Let's say you wanted 1.5 bar which pulleys would you go for? What pressures are people running on theirs? Anyone just using a multi v-belt instead of toothies?
Offline Richg40
Re: Eaton charger, what pulley sizes are you using?
« Reply #1 on: June 30, 2011, 02:22:18 pm »
Anyone?
Offline poloeatonm45
« Reply #2 on: June 30, 2011, 10:21:54 pm »
I'm running the 24 tooth pully and get around 20 psi boost. I tried a multy ribed belt but they is far too much slip I got through a belt every 30 miles cause it had to be so tight to stop slip it ran too hot and melted lol. I need a new charger pully if anyone knows where I might get one
Steve
Offline Richg40
« Reply #3 on: July 01, 2011, 07:15:24 am »
What sort of pulley diameters?
« Reply #4 on: July 01, 2011, 07:09:06 pm »
Hummm don't know to be honest my car is locked away in a garage at a friends house I. Will measure up next time in their you thinkin of getting som$e made up like ? If you are I will take a couple off you if you need to get a batch made up
Steve
Offline Richg40
« Reply #5 on: July 01, 2011, 08:18:30 pm »
Let me know the dimensions and i'll do some research.
Offline vwmk3jon
« Reply #6 on: July 02, 2011, 12:26:39 pm »
from what i remember, there were 2 different charger pulleys - 24 tooth & 27 tooth. dimensions remain a mystery as i've sold my charger since.
