Author Topic: toothed pulleys, stiped belt??  (Read 2896 times)
Offline SuperMario
« on: June 02, 2010, 04:33:19 pm »
why would a belt loose about 12 teeth? and wear out the pulleys quite bad??? after not alot of miles.
Re: toothed pulleys, stiped belt??
« Reply #1 on: June 02, 2010, 05:47:39 pm »
belts do go - they pick up stones etc.
What toothy kit are you using?
Offline giorgio
« Reply #2 on: June 02, 2010, 06:41:25 pm »
its out of alignment.
one side of your tooth will be razor sharp, caused by the full force of the teeth hitting a single point. This then chews teeth. And the vicious cycle continues
« Reply #3 on: June 02, 2010, 06:55:28 pm »
can happen if you are using a belt with the wrong tooth profile too, do you know what belt you are using?
« Reply #4 on: June 02, 2010, 07:03:12 pm »
some are just softer alloy than others
Offline wbaxter90
« Reply #5 on: July 01, 2010, 01:34:08 am »
this is bang on, its exactly what happened to me, went through 2 belts in a matter of months, changed to a steel pulley kit and found one of my old pulleys was spaced out alot more than the others and the alloy was worn more on one side.
