Was driving yesterday and when i came to a stop in traffic i spotted steam coming from the left hand side of the bonnet, i thought it was just car exhaust fumes from in front. When i parked up in the dry i opened bonnet but couldn't see no problem. I let engine run and pulled the throttle cable a little then i saw water spraying very finely towards the radiator, which was causing the steam. Where the adapter is that goes to the block, there are two connections. The top one which im not sure what it is, as in return pipe, has got a slight crack in the metal. Has anyone had a problem like this?
Is it easy to do and where can i get the part from?
Will try get a pic loaded up to show where i mean.
James
