Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Chassis & Braking
eibach springs and koni dampers combo
« previous
next »
Pages:
1
2
3
Go Down
Author
Topic: eibach springs and koni dampers combo (Read 10283 times)
mstar
Re: eibach springs and koni dampers combo
Reply #30 on:
August 10, 2010, 09:36:27 pm »
Can you list the parts convert the rear drum brakes to disc brakes? It Golf gti MK2 disc and callipers right? What else is needed?
grungeisdead
Reply #31 on:
October 26, 2010, 01:01:43 am »
there is some serious porn in this thread, i would how that dudes g60 project is going.
the g on the konis sits really well and should handle really with the koni/eibach setup and r888's, that will be a hoot on the dry roads where you are!
newt
Reply #32 on:
October 26, 2010, 09:37:11 pm »
surely if the springs are "coilbound" cutting 1 coil will make no difference to handling or rate of spring , it will just lower the thickness of 1 coil
many race cars run loose springs on coilovers (when raised up) they cause no handling issues
cutting springs is not ideal but if done properly and in the right circumstances i dont see it as a problem
Pages:
1
2
3
Go Up
« previous
next »
Club G40 Forum
Technical
Chassis & Braking
