Author Topic: Possibly oil seal fail  (Read 2479 times)
Offline Jezza-7
« on: April 01, 2012, 10:35:25 pm »
Driving today and noticed a little white smoke out the back. Went on boost and it was the same but 10 mins later when i dropped a friend off it was worse. Engine bay covered in oil from the boost return t-piece. Undid a boost pipe, turned it on and it just spluttered everywhere.
Now i had this problem a few months (without the smoke) ago but its only when running the boost mod. Could it be caused from a blockage in the oil breather pod/dome not allowing crank pressure to escape? The 25mm pipe i have coming off it was breathing but there was no oil in it at all, whereas before i have noticed there was.
Charger is only around 8k since last rebuild. There is oil everywhere though. Oil pressure gauge was fine the whole time too so i guess it couldn't be a blocked oil feed return from the charger?
Offline G40-lex
Re: Possibly oil seal fail
« Reply #1 on: September 22, 2012, 04:54:41 pm »
you ever find out what was up?
sounds very similar to what has just happened to me
lex
Offline Jezza-7
« Reply #2 on: September 22, 2012, 06:06:56 pm »
Yeah, i think it was the scroll seals, the spring on them that keeps them tight got chewed up and caused the seal to fail.
