Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40
General Car Chat
map sensor help needed???
« previous
next »
Pages: [
1
Go Down
Author
Topic: map sensor help needed??? (Read 3026 times)
poloeatonm45
on:
July 02, 2009, 09:24:12 pm »
hi as some of you will know im running an eaton convertion on my g40 and am in the process of fitting an uprated map sensor and at the moment i am trying to get a chip to suit the spec of my car and the uprated map sensor but here is my problem, i have been talking to the guys from g werx and they are saying that the 250kpa map sensor is just the standard map sensor that is fitted in a g40 from the factory and that the standard map sensor will be ok to run 20psi of boost, now i know this is not right so can someone help me explain to them that the 250kpa map sensor is an upgrade for the g40 or am i just being really stupid and the 250kpa sensor is standard?
thanks in advance for any help lads
Andy
Traders
Re: map sensor help needed???
Reply #1 on:
July 02, 2009, 09:28:39 pm »
200kPa is standard G40 - 100%! It won't register anything above around 15psi/1bar of boost, and if you repeatedly run it at significantly higher boost levels than that then you'll damage the sensor.
poloeatonm45
Reply #2 on:
July 02, 2009, 09:38:11 pm »
i knew it was not standard thanks for that info i thought i was going mad their for a sec. im kinda worried about letting them make me a chip now as i have never used g werks before and i would have thought they would of known that.
steve
Administrators
Housewives heart throb
Reply #3 on:
July 02, 2009, 09:56:50 pm »
maybe a 250 is stock in g60s/?
Alexiskayak_7
Reply #4 on:
July 02, 2009, 10:08:10 pm »
Yes, the oem map sensor reads till 1 bar, I you run 20psi have to go for a 1,5bar (250kpa) sensor so you have a full read..
vwmk3jon
Reply #5 on:
July 07, 2009, 04:28:54 pm »
mines a 250 jobbie
polo classic
Reply #6 on:
July 08, 2009, 09:39:43 am »
Quote from: vwmk3jon on July 07, 2009, 04:28:54 pm
mines a 250 jobbie
Then its not OEM. No digifant was supplied with 250's
Andy
Traders
Reply #7 on:
July 08, 2009, 01:21:56 pm »
Jon paid to have a 250kPa sensor fitted.
vwmk3jon
Reply #8 on:
July 19, 2009, 06:39:57 pm »
yup, sure did indeedy. mines eaton powered too. Gotta have the ecu apart to look at whats been done.
Pages: [
1
Go Up
« previous
next »
Club G40
General Car Chat
