Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
How to identify PY block?
« previous
next »
Pages: [
1
Go Down
Author
Topic: How to identify PY block? (Read 1898 times)
dan1300r
on:
June 07, 2013, 09:30:28 am »
Anyone know how to identify a PY Block? I am buying a used PY block to do up - want to make sure it's a PY and no other! Thanks in advance..
Administrators
The CV joint killer
Re: How to identify PY block?
Reply #1 on:
June 07, 2013, 09:36:26 am »
the engine code is faintly stamped into the side of the block right above where the top of the gearbox is and below where the dizzy would be. You'll probably need to give the area a good clean to be able to see it. It'll start with PY and then some numbers which are the unique serial number of the engine.
cheys03
Reply #2 on:
June 07, 2013, 09:37:17 am »
http://www.clubpolo.co.uk/forum/index.php?showtopic=203604
Take a wire brush with you..!
Traders
I know naathing..
Reply #3 on:
June 07, 2013, 10:39:20 am »
External webbing is different, oil drain for the charger will be tapped, and if it's always had a G40 charger mount, the top left corner will be clean.
Oh and the part number.
dan1300r
Reply #4 on:
June 07, 2013, 06:52:22 pm »
Thank you all..
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
