Cool, I love saab's, not because they are pretty, or fast or whatever. I just appreciate them from an engineering point of view. Im sure the saab kit my mate has uses crystal knock sensor. It increments boost by .1 bar until it detects knock, then it knocks it back one. There are two pots on the module that allow you to adjust how sensitive it is and what max boost you want IIRC.
Im with you for sure on listening with my ears. The cans are so useful for all sorts of other engine noises too. I remember setting up my mates nissan on the motorway on the way to york drags and I was manning the 'cans, as he accelerates I hold my thumb up whilst there is no det, then as it starts to pink a bit the thumb starts to go down. On this occasion my thumb went down shortly followed by me shouting BIG ENDS BIG ENDS BIG ENDS hahaha. Sure enough by the time we reached the slip road you could just about hear it without the cans on. It had spun the shells in a big end, so with a new rod and shells it was ok. If we hadnt been listening through the cans it would have been too late and the crank would probably have been knackered too.
The only problem is you cant wear them while you are at the drag strip. We have been looking into making a cheap system with a microphone inside a copper tube bolted to the block, playing through the stereo, but it would take a lot of fine tuning to do.
