Problem with gas fumes
Alexiskayak_7:
My G40 can not pas the gas testing at 2500rpm (it's runing rich) but in idle is great... First of all i've changed the blue temp sensor and i cleaned the injectors...
Is there a possibility 1) The lamda sond is broken?
2)Fuel pressure regulator broken?
3)Co sensor broken?
4)MAP senor?
5)Problem in ECU?
Do you have any idea what may be wrong???
PeteG40:
1. is probably the cas
3. set co2 sensor to 550 ohms
Alexiskayak_7:
What is cas???
PeteG40:
sorry - probably the case, the problem. (mistyped)
lambda probe can be seen working with an air fuel ratio meter
Alexiskayak_7:
I've checked with gas analyzer and the λ seems not to be steady at measures (it's going up and down, from 1.06 to 0.963)
Navigation
[0] Message Index
[#] Next page
Go to full version
