Technical => Engine and Transmission => Topic started by: G40 Tronster on April 29, 2010, 10:58:15 pm
Alrights guy just a quick 1 im lookin to get a fuel pressure reg. is it best to get a fixed pressure like this or adjustale like an FSA?
http://cgi.ebay.co.uk/FUEL-PRESSURE-REGULATOR-BILLET-3-BAR-WEBER-ALPHA_W0QQitemZ200434080413QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2eaacd5a9d
Cheers for any help Chris
depends what you are doing, how come you cant just use the standard one?
you dont need one really. unless you're using a different injector and inlet setup
Would you use it if you were running G60 injectors?
doesnt matter what injectors you are using. only need to change the fpr if you want to change the fuel pressure for some reason.
that one doesn't look suitable anyway as it doesn't seem to have a vacuum connection, g40 adjusts fuel pressure using vacuum/boost pressure.
