Author Topic: crank pulley bolt  (Read 3097 times)
Offline RyanC
crank pulley bolt
« on: May 24, 2014, 08:57:41 pm »
bit of a silly question but am i okay in reusing the crank pulley bolt? as it isn't a stretch bolt is it?
i know the g60 engines had problems with snapping but this was because they are stretch bolts.
it only confuses me because if you buy one from bartek it says for g60 and g40 but im sure g40 don't use stretch bolt like g60 do, and am i right in saying the g40 us 6 point bolt and g60 use 12 point
Offline samg40
  • Take.... on.... me....
Re: crank pulley bolt
« Reply #1 on: May 24, 2014, 09:40:01 pm »
I'd certainly change it if I removed it. Not worth the risk. Alex had a crank pulley fail which killed his entire engine a couple of years ago.
Offline RyanC
« Reply #2 on: May 24, 2014, 10:03:30 pm »
Okay mate just need to find the right one then as the one most places sell are stretch bolt for g60 even tho they say g40 compatible with I'm sure they are not stretch bolt on g40s
Offline samg40
« Reply #3 on: May 25, 2014, 10:30:46 am »
Pm peteg40 on here he supplies them. I replaced the actual crank pulley too, he also does those.
Offline RyanC
« Reply #4 on: May 25, 2014, 12:05:46 pm »
Ah thanks mate
« Reply #5 on: May 25, 2014, 02:05:38 pm »
Crank bolt is vw only im afraid.
I do new crank pullies.
Offline AdzCM
« Reply #6 on: May 25, 2014, 02:11:59 pm »
Yeah, you'll get your crank bolt from VW for like £6 I think. I know it's around that price.
Part number: N 902 928 02
Might aswell change the crank pulley too when you have the old one off. Pete can sort you ;)
Offline RyanC
« Reply #7 on: May 25, 2014, 03:36:41 pm »
cheers guy will do that already have a new pulley now :)
Offline samg40
« Reply #8 on: May 25, 2014, 08:02:05 pm »
Is it? I thought you got me mine. Did you pick it up for me or something?
« Reply #9 on: May 25, 2014, 08:07:24 pm »
yep I did
