Author Topic: Which Lambda probe?  (Read 1690 times)
Offline Justin14100
Which Lambda probe?
« on: September 25, 2009, 01:57:55 am »
OK, so finally found my running problems, unplugged the lambda and its running MUCH better!
Looking on ETKA, there are 2 lambda sensors.
030 906 265J - PY, AAU, 3F, NZ
and
030 906 265N - PY for models without catalyst... ]
I have a decat pipe so would it be better to get the second one? Will it even make a difference?
Thanks!
Re: Which Lambda probe?
« Reply #1 on: September 25, 2009, 08:14:16 am »
the second is one for the euro ECUs which were preprogrammed to run without a cat (as laws over there didn't need one).
Use a standard catted one.
« Reply #2 on: September 25, 2009, 08:50:25 am »
The only difference will be cable length - the actual sensor should be the same.
« Reply #3 on: September 25, 2009, 09:05:45 am »
thats what i thought after i posted.  Most lambdas are very similar anyway, just the plug on the end.
