Djtez - I have already got a full blend charger, Gt inlet mani, 4-2-1 exhuast, I rebuilt the head with new valve guides stem seals and all valves cut/lapped also a bit of porting to the head to match te inlet and exhuast, 65mm pulley, de cat, I rebuilt the bottom end as well. It also has a helix organic clutch And probably some other things I have forgotten.
So I'll only be going down the path of handling/cooling with maybe a little more power.
But the shifter does look amazing!
Bread man - I will be investing in a subframe at a similar time, I would go for an LSD as it would probably be one of the best mods you can do but after buying the unit and fitting it your looking around the £1000 mark unless I fitted it myself and I haven't stripped a box yet do it would take me awhile to say the least.
My g40 is half stripped already and I'm planning on shedding as much weight as I can so it will do in lovely.
