Author Topic: Ball joint refurb  (Read 8923 times)
Offline RyanC
Ball joint refurb
« on: July 09, 2013, 10:48:04 pm »
I've got some g40 TCA with the rose jointed inner joint but the outer ball joints are worn out, dose anyone know if there is anywhere you can get new joints put in or refurb kit so I can do it my self, its only a pressed in ball and socket,
You can't get the g40 TCAs anymore so don't want to chuck them!
Offline scotsjohn
Re: Ball joint refurb
« Reply #1 on: July 10, 2013, 12:34:43 pm »
Should be able to find a couple of sites in Classic Car Magazine and suchlike.
Offline Jezza-7
« Reply #2 on: July 10, 2013, 02:06:30 pm »
this guy does the trick quite well
http://www.youtube.com/watch?v=PZLxPyRdAbY
Offline RyanC
« Reply #3 on: July 10, 2013, 06:38:30 pm »
kool thanks guys
Offline JoeH
« Reply #4 on: July 10, 2013, 07:12:08 pm »
Would it be worth getting the rose joint done to?
Offline z3i
« Reply #5 on: July 10, 2013, 08:31:22 pm »
where do you get the little rubber boots from? on its own? and same for the track rod ends, mine are split but in perfect working order, and yeah can you not push a rose joint into the inner one?
Offline breadman
« Reply #6 on: July 10, 2013, 09:58:50 pm »
Bloody hell, he did that quick! :D
« Reply #7 on: July 10, 2013, 10:24:55 pm »
ebay!
« Reply #8 on: July 11, 2013, 11:07:32 am »
that's a cool video, I might give it a go with an old TCA.  What is he welding part way through though?  Is he just doing that to get some heat into the metal to push the ball joint outer casing out? (and/or welding a ridge to push it out with)?
Offline Jezza-7
« Reply #9 on: July 11, 2013, 12:05:54 pm »
Yeah i thought about getting an old one as well. Wonder what size ball joint will be needed?
I would of thought it would be to do with getting it really hot, as it would expand then quickly cooling it to make it contract so it comes out easier.
Will send him a message on youtube.
« Reply #10 on: July 11, 2013, 01:38:53 pm »
He grinds the old balljoint down to separate the ball/thread part from the bearing and smashes the ball/threaded part out. That leaves the bearing race in-situ, so he runs a bead of weld around it to get it hot before throwing it in the water to make it contract uber-quickly and drop out.
« Reply #11 on: July 11, 2013, 01:50:44 pm »
As Andy said- it also works if you leave them to air cool, I've done it on a stubborn wheel bearing race before, bead of weld round, allow to cool, weld/race contract and pop out.
Neat trick providing you don't weld the race to the housing...
Offline RyanC
« Reply #12 on: July 11, 2013, 10:18:29 pm »
it cant be to hard to change them tbo as long as we can find the right size joint to put back in i might try to get mine out soon, would be nice to save the g40 tca's. will let you know how i get on
Offline RyanC
« Reply #13 on: August 26, 2013, 06:53:20 pm »
Dose anyone know if the rose joints can be pressed out? Or are they in with cir-clips (haven't look yet) Been looking for replacement ball joints cant find any in the size I want so im thinking of taking the rose joint out getting standard arms and getting them machined so the joint can be pressed in because standard arm inner diameter is smaller and tapered for the bush to fit.
Offline RyanC
« Reply #14 on: August 27, 2013, 08:57:35 pm »
Right Ive managed to press the rose joints out! So I'm going to buy some standard arms and get them machined out so I can press the rose joints in hopfully if the standard diameter is smaller witch I'm sure it is.
I will get some pictures up when u get the measurement
