Author Topic: ATV rebuild  (Read 5706 times)
Offline g40Ross
Re: ATV rebuild
« Reply #15 on: May 28, 2010, 04:27:38 pm »
Quote
G40 standard gear box:
Top gear gives 23.121 mph/1000rpm and top speed of 161.846 mph at 7000rpm (hence G40's 160mph clocks)
Engine speed in fifth:
30mph=1298 rpm
40mph=1730 rpm
50mph=2163 rpm
60mph=2595 rpm
70mph=3028 rpm
80mph=3460 rpm
90mph=3893 rpm
100mph=4325 rpm
top speed in 1st=39.876 mph, change in to 2nd at 4246 rpm dropping 2754 rpm.
top speed in 2nd=65.743 mph, change in to 3rd at 4905 rpm dropping 2095 rpm.
top speed in 3rd=93.882 mph, change in to 4th at 5231 rpm dropping 1769 rpm.
top speed in 4th=125.552 mph, change in to 5th at5430 rpm dropping 1570 rpm.
top speed in 5th=161.846 mph at 7000 rpm.
this is for the standard gearbox yeah?
mine tops out in 2nd gear at about 56mph!
Offline leeg40
Re: ATV rebuild
« Reply #16 on: May 29, 2010, 09:09:56 am »
Hi, yes the above is for the standard box, 56 sounds about right, what you have to take in to consideration is that the figures above are from a gear speed calculator, which does not see wind resistence/aroedynamic drag of the car, gradients of the road etc etc. We all know that in reality a G40 can not achive 161.846mph in 5th but on paper that's what it's geared to do but take in to consideration all other factors and you get a considerably lower figure.
Offline Andy
Re: ATV rebuild
« Reply #17 on: May 29, 2010, 07:55:03 pm »
Bare in mind the figures quoted there aren't for a stock rev limiter.
