Author Topic: Wounded charger.... help  (Read 6352 times)
Offline Etches
  • Still got the G...
« on: August 31, 2010, 05:44:28 pm »
Right, picked up this charger with the rest of the clobber from FORCEDINDUCTION off here, dam good deal we got. The main problem is this charger, service historys good and well within its next one. The owner before last managed to wear a hole in casing as shown in the above pics. My thoughts were just to change the casing for a different one and inspect aswell as  asking pete for advice ( I only live in crooks which isnt far to penistone) and to have a nosy. Just thought i'd pop it up here n see what y'all think.
Etches
Re: Wounded charger.... help
« Reply #1 on: August 31, 2010, 06:11:15 pm »
pop in some time - or i'm often in crookes.  I'll tell you what's fucked on it (whether its just the casing or whether scroll etc is shagged)
pete
Offline kayl0rz
« Reply #2 on: August 31, 2010, 08:48:35 pm »
Hiyaaaa
Its my charger :)
From what we know the hole was worn in by a rad being too close, or something along those lines. so i imagine its just the casing. however one cannot help but wonder about shrapnel. the worn bits have to go somewhere.
Etches has the charger with him, but his G is currently... 'off the road'
i imagine though by now he would have Pm'd you!
Offline Nick_S
  • 189.6 bhp @ 8psi boost
« Reply #3 on: August 31, 2010, 09:10:47 pm »
Ummmm that does look like melt rather than shatter damage. Radiator wouldn't get hot enough to do that, so could be a welder?
I have a spare casing for that side if thats all thats kaput ;)
Offline kayl0rz
« Reply #4 on: August 31, 2010, 09:12:51 pm »
from what was said, sounded like the rad rubbed and rubbed and eventually wore through?
although i could imagine it would take a lot of rubbing to get through metal. regardless of what you, or your rad, were made out of!
Offline GR40
« Reply #5 on: September 01, 2010, 09:10:59 am »
it looks repairable to me! I think you could tig weld the hole and reshape the inside! It looks like it rubbed on the metal cover that holds the fun! but I have no idea how these two came close enough!
« Reply #6 on: September 01, 2010, 09:29:28 am »
got to be careful welding - if it deforms with heat even a few mm it'll grenade the charger.
« Reply #7 on: September 01, 2010, 10:11:09 am »
I'd not even bother trying to weld it up, casing halves are usually obtainable, it's the scrolls that are harder to find on their own.  Take Pete up on his kind offer and let him have a butchers inside, he knows his way round the internals of chargers!
Offline xandyx
« Reply #8 on: September 01, 2010, 12:24:00 pm »
hi there!
check on ebay.de
yesterday i was looking at g40 parts and there was a guy breaking in parts a g40 charger. check is he still has the left case.
Offline Nick_S
« Reply #9 on: September 01, 2010, 07:18:52 pm »
hi there!
check on ebay.de
 ;D
Offline Etches
« Reply #10 on: September 02, 2010, 02:55:00 am »
pete
If your going to Vw action pete shall bring it to that if you like
« Reply #11 on: September 02, 2010, 08:49:42 am »
probably not mate
Offline Etches
« Reply #12 on: September 02, 2010, 01:54:58 pm »
thats fine shall make a trip down after then cheers pete
Offline tdh-syorks
« Reply #13 on: September 02, 2010, 04:56:05 pm »
my monies on it grenaded, the hole looks too big for "wear" you'd have noticed and removed it long before that damage.  8) ::)
Offline scotsjohn
« Reply #14 on: September 02, 2010, 09:38:51 pm »
Nice hex shaped hole though.
