Author Topic: G60 charger on standard engine  (Read 2004 times)
Offline benh999
  • K776PKR finally back home
« on: April 14, 2016, 05:01:16 pm »
G60 Blower onto a standard G40 block and head
Has this been done?
what are the pitfalls i.e is the bottom end strong enough to cope etc
Offline JoeH
Re: G60 charger on standard engine
« Reply #1 on: April 14, 2016, 09:41:23 pm »
The Beauty of the G60 is that one could run a larger pulley and thereby keep same boost as G40 but with less stress.
Not sure you can fit G60 with G40 mount or intercooler
Offline polo classic
« Reply #2 on: April 15, 2016, 01:19:35 pm »
Problem is that the G40 gains revs much faster than the "layzy" G60, causing the chargers scroll walls to flex. With a smaller pulley it is even worse. You can't go much smaller on the pulley either before you end up with more boost than the Map-sensor can read
