Author Topic: Oil cooler positioning.  (Read 1251 times)
Offline breadman
« on: January 15, 2011, 08:24:44 pm »
Is there any reason why I shouldn't fit my oil cooler (next to the radiator) up under the slam panel with the fittings facing down? I just wondered if it might be a problem being mounted so high up? It'd mean nice short hose runs and a tidy install but more importantly there ain't nowhere else to fit it! (mk2 Polo).
Cheers,
Richard.
Re: Oil cooler positioning.
« Reply #1 on: January 16, 2011, 10:25:55 am »
I've seen others fitted there so don't think it's a problem
Offline grungeisdead
« Reply #2 on: January 16, 2011, 07:16:22 pm »
oil coolers come as standard on mk1 golf gtis and are positioned to the left of the radiator so it shouldnt be a problem. if you get an oil temp guage as well, you can determine if your oil temps are acceptable and if not, seek to reposition it elsewhere
Offline breadman
« Reply #3 on: January 16, 2011, 09:57:13 pm »
Cheers guys.
I will have plenty of airflow to the oil cooler, I was just a little worried about the actual height of the cooler in relation to the engine. Seems like I should be ok though if others have fitted them in a similar place.
Thanks again.
Offline vwmk3jon
« Reply #4 on: January 19, 2011, 08:33:43 pm »
Kano on Polo3 has his fitted right underneath the bonnet catch behind the grille.
Offline alan gorst
« Reply #5 on: January 25, 2011, 11:53:39 pm »
mine is fitter directly under the bonnet catch also behind my grill and it seems fine there
