Author Topic: What lowering springs with shorten yellow Koni  (Read 2227 times)
Offline GeirJB
  • Its not a trick, its a polo!
« on: August 09, 2013, 09:09:09 am »
I need a new set of lowering springs! I got shortened Yellow Koni shocks!
But not sure what springs i will go for!
Its not a daily driver and will be used on the track!
Need to change springs because of MOT
How it sits now on old KW tuning springs. wheels are 7x15 et 25 Intra with 165/45-15 Federal tyres
Offline Phil
Re: What lowering springs with shorten yellow Koni
« Reply #1 on: August 09, 2013, 02:13:32 pm »
If its for pure track I'd look on for some motorsport springs from whichever make, but the bump on the koni's will ideally need to be revalved to suit, if that isn't an option you'll be better off keeping your KWs or going for H&R the latter being a bit stiffer.
Offline GeirJB
« Reply #2 on: August 10, 2013, 06:31:57 am »
I will check out H&R springs! But I dont want the car to be higher than on the picture! Dont now how much the KW springs lowers! Been looking at coilovers, but not sure how much money I want to use on my Polo. Is Ta Technix any good?
I need Springs or Coilovers with TÜV because of that stupid Norwegian car approval system! The KW springs i have now are written in the car registration, but it was measured 2 cm lower than when it was approved in 1998, so I need to get some new ones!
