Author Topic: help with turboing  (Read 5419 times)
Offline vee-dub90
    • Facebook
help with turboing
« on: April 21, 2012, 12:36:28 pm »
Currently my car is running a 5th gen m45 eaton with 310cc injectors and i plan on taking it all off, and running a k03 and i just want some advice on what i should use etc? I'd like to make about 190bhp running about 1.5 bar
so far i plan on getting:
wossner 77mm pistons to take it upto 1341
some forged rods too (can anyone recommend any? or do i keep stock rods?)
kkk k03
philj manifold and downpipe
decent cam
mocal oil cooler
I plan on doing some headwork too
a ppp chip
Offline vee-dub90
    • Facebook
Re: help with turboing
« Reply #1 on: April 27, 2012, 01:44:36 am »
anyone at all?
Offline AlexG40
« Reply #2 on: April 27, 2012, 01:54:31 am »
Most people don't change the stock PY rods. They seem to be good for large power.
Offline vee-dub90
    • Facebook
« Reply #3 on: April 27, 2012, 02:08:14 am »
i was just curious if its worth getting forged really, but i guess i could use stock
« Reply #4 on: April 27, 2012, 02:15:08 pm »
No one has ever had trouble with rods to my knowledge, I'd save your money there.  Budget for a custom remap too.
Offline vee-dub90
    • Facebook
« Reply #5 on: April 28, 2012, 01:29:47 am »
i shall use stock rods then, any recommendations on what spec cam i could go for? also things like, would it be worth getting the crank balanced etc?
« Reply #6 on: April 28, 2012, 04:54:10 pm »
With a k03 you want something like a 268/268. I think PPP can source these.
Offline vee-dub90
    • Facebook
« Reply #7 on: April 28, 2012, 09:00:57 pm »
arent the newman cams 268/268?
Offline vee-dub90
    • Facebook
« Reply #8 on: April 30, 2012, 12:20:11 am »
also, what head gasket would i run?
Offline dub-disaster
« Reply #9 on: April 30, 2012, 06:25:27 am »
I run a standard victor rienz one from vag  on mine. you can run a metal one if you want from something like aex  engine but it will raise your compression ratio slightly due to it being slightly thinner.
Offline timmitime
« Reply #10 on: April 30, 2012, 04:49:37 pm »
Im running 2 aee headgaskets and a decompression plate on a 1.6 aee lupo turbo with a k03, frontmount, newmann 268 268 schrick copy cam, 250cc injectors, modified head and a ppp live map and my car has just done 1000 miles with no problems all on standard internals
Offline AlexG40
« Reply #11 on: April 30, 2012, 06:08:30 pm »
How much does this raise the ratio by?   Enough to care or not?
Offline prankstar2003
« Reply #12 on: April 30, 2012, 10:21:17 pm »
What boost levels are you running on this set up? Whats the spec on the decomp plate?
« Reply #13 on: May 01, 2012, 06:24:40 am »
http://www.polog40.co.uk/forum/index.php/topic,2319.0.html have a look at that thread its all in there
Offline randombadger69
« Reply #14 on: May 02, 2012, 02:17:23 am »
Worth noting the standard Victor Reinz gasket is no longer available from VW, but is the part elring supply, available from RS engine Supplies.
