Author Topic: Polo G40 Cup rule book  (Read 5438 times)
« on: June 03, 2009, 10:12:56 am »
just a random thought, I assume that when the g40 cup existed in the early 90s a rule book of some sort was written.  Does anyone happen to have a copy of this and if so could they scan it in?
Offline G40supercharged
Re: Polo G40 Cup rule book
« Reply #1 on: June 03, 2009, 06:06:03 pm »
Have a look at http://www.pitstopdevelopments.com/cuprebuild07/supercoupe.pdf
As I understand it the regulations for the super coupe cup G40s were largerly based on the original G40 cup car regs.
I may have an earlier copy of the super coupe cup regs if I can find it.
« Reply #2 on: June 03, 2009, 07:04:12 pm »
nice one, that's pretty interesting, the poo g40 specific section.
Offline G40motorsport
« Reply #3 on: June 03, 2009, 07:28:34 pm »
Yep, the Super Coupe Cup carried over the G40 Cup regs unchanged.
Offline pettsy
« Reply #4 on: June 05, 2009, 12:18:26 am »
interesting reading  ;D
Offline sema-motorsport
« Reply #5 on: July 25, 2009, 12:35:21 pm »
Good afternoon!
I use my Polo G40 only on the race cource and I`m very intersting about the super coupe cup rules. But the link from G40supercharged actualy doesn't works.
Can anyboddy provide a link for me again? Or send me the Cup Rules to my e-mail address?
Thanks a lot!
kind regards from Germany :)
Sebastian
« Reply #6 on: July 27, 2009, 08:56:07 am »
PDF file for super coupe cup regs.
« Reply #7 on: July 27, 2009, 12:03:57 pm »
Thanks a lot, it is very helpful for me :)
Have you more detailed informations about the setup of the Cup-Polos (for excample the wheel alignment)
One picture of my G40:
I know, the steering-wheel is on the wrong side ;D
cheers,
Sebastian
« Reply #8 on: July 27, 2009, 11:08:29 pm »
Personally I run my car like this
Front tracking is toe out, can't remember how much.
Max caster, max camber.
Rear dampers are heavily bump rubbererd, I run the rear in parallel with no camber or sometimes half a degree positive.
Run the brakes with the bias to the front, virtually no rear brakes.
I like the car to have sharp turn in and drive the car by the front, the rear is very lively especially on cold tyres but I have found that is the fastest way for me to set it up.
« Reply #9 on: July 28, 2009, 08:02:30 am »
Thanks,
Your setup is similar the same like the German cup cars. But I cannot find out the exact value from the front tracking.  The correct front tracking is very important, otherwise I have many problems with the grip of my front tires.
