Author Topic: 1W crank, G40 block, machining?  (Read 2150 times)
Offline Richg40
« on: May 16, 2010, 06:28:30 pm »
Ok, does anyone have a definative answer on exactly how much machining a G40 block would need to accept a 1w crank? I'm struggling to find detailed info on this build.
Rich.
Offline Richg40
Re: 1W crank, G40 block, machining?
« Reply #1 on: May 17, 2010, 06:21:52 pm »
Any ideas?
Offline poloeatonm45
« Reply #2 on: May 19, 2010, 05:45:48 pm »
i emialed the guy who you got this from on ebay and he said some dont need it at all but others need around 2-3mm taking off. i would of thought it would be a case of just try it and turn the crank by hand to see if it clears, if it dont grind a bit out and try again
steven
Offline Richg40
« Reply #3 on: May 19, 2010, 08:17:20 pm »
yeah, i got the same impression from everything i've read. finding actual real info that can be relied on is tricky.
« Reply #4 on: May 19, 2010, 09:11:11 pm »
I think that's because people with 1Ws have used the 1W block so far haven't they?  Going to be a case of suck it and see I think, put the crank in and see what the score is.
Offline Richg40
« Reply #5 on: May 19, 2010, 09:17:38 pm »
Block is off being rebored, i'll feedback on this when it's done.
Offline Richg40
« Reply #6 on: July 01, 2010, 09:00:39 pm »
Well i finally got it back. Having tried the crank and pistons the flat end of the big end cap bolts catches a tiny bit on the block oil gallery. After shaving a gnats chuff off the head of the bolt it runs sweet.
« Reply #7 on: July 01, 2010, 09:09:10 pm »
i'd have taken a bit off the block not bolt - will it not be unbalanced/
Offline youngprodigys
  • G 3URO
« Reply #8 on: July 01, 2010, 11:05:09 pm »
as above - surely the block was the best thing to chop???
Offline Richg40
« Reply #9 on: July 01, 2010, 11:25:34 pm »
Both bolts on each conrod have been skimmed. Can't cut into oil line too risky.
