Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Superchargers / G-Lader
removing the pulley
« previous
next »
Pages: [
1
Go Down
Author
Topic: removing the pulley (Read 2779 times)
g40Ross
removing the pulley
on:
November 20, 2010, 04:39:30 pm »
can anyone give me some advice on how to remove the pulley from my charger as its dead and its time for a swap?
thanks in advance
Ross
dannyb.G40
Re: removing the pulley
Reply #1 on:
November 20, 2010, 05:49:31 pm »
Airgun is probably the best, I've always used a pair of stilsons or a vice but be careful not to damage the pulley.
g40Ross
Reply #2 on:
November 20, 2010, 06:00:04 pm »
it just turns the pulley when i do that is it just notis there anything i can do to stop the pulley turning?
cheers
Ross
Reply #3 on:
November 20, 2010, 06:11:32 pm »
put an old belt around the pulley and clamp it. Then undo it.
newt
Reply #4 on:
November 20, 2010, 10:14:47 pm »
Quote from: Jezza-7 on November 20, 2010, 06:11:32 pm
you running tooth belt or v belts as if your on v belts and they are a little worn you will mark the pulley
water pump pliers/stilsons with a iece of leather /rubber will work , used this technique many a time
g40Ross
Reply #5 on:
November 21, 2010, 01:12:28 pm »
im on toothed pulleys
woody02
Reply #6 on:
November 21, 2010, 01:13:38 pm »
got mine off with a cordless impact gun, worked ok, or nip the charger to a local garage and see if they will loosen it for you
Nick_S
189.6 bhp @ 8psi boost
Reply #7 on:
November 21, 2010, 01:39:39 pm »
Lock off the turning with stilsons or large chain whip filter remover.
Administrators
Housewives heart throb
Reply #8 on:
November 21, 2010, 11:56:08 pm »
toothies, i tend to use a chain whip with old belt on it to stop damage
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
removing the pulley
