Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
1w crank
« previous
next »
Pages: [
1
2
Go Down
Author
Topic: 1w crank (Read 4601 times)
G40_POWER_AD
1w crank
on:
June 04, 2012, 10:46:11 pm »
hello mates, the 1w crank directly fit on PY block or need some more modifications ? i pretend use original pistons and rods...i buy a decompression plate 1mm if it need to lowering compression
youngprodigys
G 3URO
Re: 1w crank
Reply #1 on:
June 06, 2012, 11:42:01 pm »
no it doesn't, the conrod bolts hit the block. you need to grind the block away.
The original G40 pistons? they will NOT fit as they will be long and hit the head.
G40_POWER_AD
Re: 1w crank
Reply #2 on:
June 07, 2012, 12:25:08 pm »
tanks mate ! i think the best option is to using the 1w block with g40 pistons or 77mm ones
Administrators
The CV joint killer
Re: 1w crank
Reply #3 on:
June 07, 2012, 12:38:06 pm »
you can't use g40 pistons with a 1W, you need custom-made ones.
G40_POWER_AD
Re: 1w crank
Reply #4 on:
June 07, 2012, 04:52:17 pm »
what i need to use 1w crank ?
Administrators
The CV joint killer
Re: 1w crank
Reply #5 on:
June 07, 2012, 05:08:41 pm »
sorry I don't understand what you are asking there. If you want to use a 1W crank, whether this is with a G40 block (which would need machining/grinding) or a 1W block, you cannot use standard G40 pistons, you need to get some specially made ones.
G40_POWER_AD
Re: 1w crank
Reply #6 on:
June 07, 2012, 07:05:15 pm »
ok mate i see ! i go try to buy a 1w block...
youngprodigys
G 3URO
Re: 1w crank
Reply #7 on:
June 07, 2012, 10:53:05 pm »
you still need new pistons
G40_POWER_AD
Re: 1w crank
Reply #8 on:
June 08, 2012, 12:38:56 am »
yes yes i understand ! i think the best option is to buy a new wossner forged pistons
youngprodigys
G 3URO
Re: 1w crank
Reply #9 on:
June 08, 2012, 04:44:44 pm »
Left 1W piston accralite forged
Right standard G40 piston
G40_POWER_AD
Re: 1w crank
Reply #10 on:
June 08, 2012, 09:43:05 pm »
i see ! but the "wossner" or "wisseco" piston it is the same type of this piston in the left side ? or it is a diferent one ?
xandyx
Re: 1w crank
Reply #11 on:
June 09, 2012, 01:28:28 am »
it will be forger, no matter what brand is, otherwise it may have different compression ratios.
G40_POWER_AD
Re: 1w crank
Reply #12 on:
June 09, 2012, 03:14:03 pm »
but i think for the good function of the engine is to maintain the original compression yes ?
s.e-power
Re: 1w crank
Reply #13 on:
June 10, 2012, 02:35:45 am »
You can use the good 1w on the block with the pistons of PY G40 and they body will have to be machined to stay with the same rate Companding I have to sell these pistons with diameters of 75.01 / 75.51 / 75.76 attention but you have to 1W as it may be to 78.7 or 79.1 of the pistons and maquinamento ja and other and even to buy other type JE pistons or WISSECO or other have to know what is the measure of your 1W
youngprodigys
G 3URO
Re: 1w crank
Reply #14 on:
June 10, 2012, 06:45:17 pm »
that last post did not make much sense.
The maximum piston size you can use on the block is 77mm. it is the height that changes to bring down the compression and also make it not hit the head on TDC.
my previous post shows the height difference between the pistons
Pages: [
1
2
Go Up
« previous
next »
Technical
1w crank
