I have a list of parts and seals etc that im looking at buying for when my head goes on. The head has been skimmed and im going to stick with a VAG for all the parts, unless they dont have them or if there are any recomendations for other companys to use?
If there is anything i have missed out or you reckon its worth replacing while the heads off, please let me know.
For the cam:
Camshaft Bolt & washer, N 90256201, 027 109 143
New tappets (INA)
Timing end and dizzy end seals (3 of them) 030103085A, 030905261, 030905224
Rocker gasket 030103483C
Head:
Head bolts x 10 030103384 & washers, no part number on vagcat for washers for PY
Head Gasket 030103383R
Exhaust gaskets x 2 030 253 039A
Inlet gasket 030129717D
Throttle body gasket 030133073A
Inlet manifold bolts x 6 N 0447311, washers x 8 N 01155811, 2 nuts N 01100830
Throttle body bolts x 4 N 0147053 & 4 spring washer N 0122265
Bearing cap nuts x 10 N 10045301
Possibly thermostat housing 030121117M
Thermostat 030121113
Thermostat housing seal 030121119
Temp sensor 025906041A
Temp sender 251919501D
Connection socket 030121121B & seal 038121119B
Housing bolts x 2 N 0103324 & 2 spring washer N 0122293
Exhaust studs x 8 N 044 410 4, washers x8 N 011 558 11 & nuts x8 N 900 850 01
New plugs GSF or ECP
Timing belt 030 109 119A
Windage tray:
2 sump seals 032103609B
Longer bolts loads of
All i can think of for now.
Head has done 60k
